Few questions after hydroboost install
Had the exact problem with the reman booster I bought. Like Jeremy said earlier...a properly functioning HB WILL lock all 4 wheels with about 1/2" pedal travel....EVERY TIME. Try a different booster and report back.
New booster will be in Mon....I post back after I put it on. THANKS FOR THE HELP!!!!
New hydroboost is on, still have the soft pedal. I'll be changing the master later on in the week. I believe thats the problem because when I pulled off the master there was some fluid (brake fluid, clear) on the hydrobooster where they meet. I guess the small leak is not letting the master seal properly. When I pump the pedal (when the cars is running) once in awhile it seals and works for that pump. As soon as I release and pump again it goes to the floor. Any other ideas?? Still a TON better than stock and IF you drive with care it's not a problem.....but it's not right.
Getting closer! Yeah i'm thinking the master must be an issue. You definately shouldnt have any fluid between the master and the booster. Sounds like a bad seal.
