SignUp Now!Anyone have any tips? I installed my old one and ended up not being able to put the pan on. Is there a magic trick or am I slow?
We put the o-ring on the filter--then a little trans.fluid for lub. and insert/push-up in opening. Filter will be very close to valve-body.I didn't see an o-ring. It will be on the filler/dip stick tube correct? I guess I need to get a pick and go to town.
It also seems like the filler tube and the valve body are too close together. Do I put the o ring on the filter or on the tube?
Thanks guys.
Anyone have a refrence pic of which way the filter should be turned?
Just keep spinning it until the pan fits:biggrin:
