Finally finished with TTA fab. project!
turbofabricator
Here's a few pics of the TTA project that I have been working on for a friend.
It has a 3.5" oval downpipe, 3.5" oval intercooler plumbing (under the radiator for ground clearance), Precision front mount intercooler, TE-63 turbo, 50lb. injectors, 4" MegaMAF (modified to fit the TTA), 70mm TB, polished plenum, 1007 wire-lock head gaskets, ported heads, hydraulic roller cam, Adjustable pushrods, stock rotating assy., ARP head bolts, ported intake, Turbo-Smart wastegate, GenII translator, dual external Bosch fuel pumps, 1/2" stainless feed out of tank, (the GM engineers should be BEATEN for the stock fuel pump/tank design on a TTA!:mad: ), 1/2" stainless feed line, -8AN chassis to rail lines, Precision Industries 9-11 converter, LC-1 WB O2, 3" stainless exhaust, dual 3.5" oval stainless exhaust tips, and a TON of other little "tweaks".
Should I keep my day job?
more pics of the underside with the intercooler pipes ,and the oval tip for the exhaust...thanks
