finally got the trans in...
plcguru
Wow, finally got the 200-4r in after building it for how many months... Seems to work great, firm shifts but not neck breaking. LOVE it! I would never have even attempted building it if it wasn't for the knowledge I found reading the posts on this forum :biggrin:
Just want to make sure all is well so I'm comfortable it will live a while since it's my first tranny build.
It's a CQ model with CK's latest shift kit and servo. Dual fed. ProTorque 12" converter
My pressures are: min/max tv
park.75...240
rev..125..300
neu..75...240
d4...75...240
d3...75...225
d2...225...250
d1...225...260
It seems to shift fine but I like I said it's my first build and I put soooooo much time into it I want to make sure it will last.
Are my pressures ok??
Pressures are good,but you may want to give it a click or 2 to get 85 at minimum tv.If you like where the cable is put a .100 thick washer betwwen the tv plunger and spring.itll raise it up without messing with the cable.
