Start the car no problems, idles for about 3-4 seconds and then dies. It's a fairly stock car, only upgraded to 87 coilpacks at this point. Cat is not clogged (dropped the exhaust, same problem), turbo spins, unhooked and cleaned the MAF same problem, fuel pressure is good, cleaned the IAC/TB, pretty sure it isn't vacuum related. Any suggestions before I get serious and tear into this piece? I was thinking maybe a crank or cam sensor? Thanks guys,
Larry
Larry
