turbo87adam
- Mar 18, 2012
Have you tried jumping power to the fuel pump test wire behind alternator. That will hot wire the fuel pump on for testing.
SignUp Now!I did this so that I didnt have to set the B*tch up like said I had a horrible time getting it right in another engine so for me this is last resort for sure.
Yes that was actually happening to me Bob. It also didn’t help that the window in the sensor had a broken tab lol .I have seen/heard *one time* where the cam sensor was mistimed and the engine would start and run for a couple seconds. I would be the first to say that it is not possible for this to happen, that it should start, or not... but it did happen.
until the cam sensor timing is checked, we don't know.
Verified Fuel pressure with my wife last night it is good stayed steady while running then died all I had time for Ill be swaping the MAF this weekend and see what that does.You have a kid or girlfriend/wife that can watch the fuel pressure gauge or start the car so you can watch the gauge?
Wait, stop right there! You said the fuel pressure "stayed steady while running then died" correct? If so, that's where you half step your troubleshooting....... Like mentioned more than a few times already: JUMPER THE PUMP and see if it stays running. Take it from there.Verified Fuel pressure with my wife last night it is good stayed steady while running then died all I had time for Ill be swaping the MAF this weekend and see what that does.
Did you unplug the translator from the car harness? If not try that.
"HAY WHY THE BOX?" I said what? He said there wasnt one on it with the old MAF! LMAO I said "YOUR RIGHT!" Took the Translator out and plugged the LT1 MAF In directly the way it was when I took it apart and WALLA!
Somethings up. A LT1 MAF will not physically plug into a stock harness. It will only plug into a Translator harness. (only a stock style MAF will plug into the harness)
Are you sure you're not confusing a stock style MAF for an LT1 unit?
This is whats on it now not shown is the Adapter plug that connects to the factory wiring harness
This is an old Photo (Looks way way different now) but that is the sensor in the pipe on the car that is an LT1 MAF Correct ?
