- Apr 4, 2002
of what a GN should look like.
It represents the GN community perfectly!
Way to go Mike!![]()
Thanks Lee. All it needs now is purple window tint and some yeehaa pipes and it'll be good to go.
Mike B.
SignUp Now!of what a GN should look like.
Mike B.
I contacted budnik about a 17x8 and 17x9 for the rear. But I was told they were only available in 17x9.5 for the rear. Will this fit with 4.75" backspacing? I remember my 17x9's were "close" to rubbing. Is there anyone out there running 17x9.5's in the rear with no modifications to the frame etc? And if so, what size tires are you running?
I don't think 75% of just ONE coil is going to make that much difference in spring rate, and even if it did the risk-vs-reward wins out becuase the center of gravity is lowered.
And if that weren't bad enough, recommending dropped spindles (given how poor the G-body geometry is) over a good upper control arm like the Savitske Classic & Custom is absurd.
I have cut the springs in several of my cars over the years. Never had any ill effects. Didn't go crazy. Just a 2'' drop or so.
1966 impala, 1970 chevelle, 1994 mustang, and a 1964 chevy II.
I say get the whiz wheel out and go to town.
Mike,
When you wake up, be sure to paint your brake drums black.
Thanks,
Bill![]()
From what I understand, four or five sets have been made.
Also, on a side note. I had to pop out the center disks from my old hub caps to use for the new alum ones. I just drilled a small hole in the back of the hub. Pushed out the disk with a small screwdriver. Old caps pop out cleaner than new ones due to the fact that the silicone starts to let go after years. I heard that Mark Hueffman makes custom caps too.
Rim pics anyone?
Mike Barnard
It looks as if those arent painted correct? Man do those look nice though!
