Well, I went through the entire spring cleaning list, I replaced the powermaster.
First, I need the passenger's side black metal trim piece under the t-top, the outside end is rotted. I pulled it off and underneath has some surface rust, but nothing terribly bad. Does any one know where I can find the black metal trim piece. I guess with some effort I could likely make one, but would take me forever.
Second, after a couple of hard acceleration blasts the check engine light came on. I shut down, restarted, no light, couple of runs and light back on. I don't have a code reader for the older cars, is there any trick to figuring out the code without a reader? Turn key on, right blinker, jump on left foot while drinking a glass of water?
Third, my brakes are just not strong, pedal does not go to floor, nor is it rock hard, just takes a lot of force to stop and I can't lock brakes and I can't hold any boost at all.
I have not yet bled rear brakes, so I will bleed everything from scratch and see if that does the trick.
Finally, the guys at the parts counter gave me the wrong serpentine belt and the tensionner pulley is rubbing against the AC bolt. They gave me a drive rite 5060640DR 6PK1625 belt.
Oh and a bumper filler snapped when cleaning, I need to find these also now. (all you old timers are snickering I'm sure as my list is likely very familiar).
Good news, no leaks (other than very slow rear main) and my AC held vacuum after replacing o-rings, orifice valve and accumulator.
Thanks guys,
Joel
Thanks guys,
Joel
