A reading of 29 ohms is in the ballpark. It may be that the connector, wiring, or the ECM is bad. The quad-drivers that operate the various relays & solenoids do go bad. Usually there is physical damage to them that makes it apparent. In this case will need to check the resistance of the other devices.
To test the actuator use an air compressor. A stock actuator, IIRC, opens at about 13 psi, a HD at about 18 psi.
Put the air to the port on the actuator that has the hose on it. It should open the waste gate by pulling the rod toward the actuator.
RemoveBeforeFlight
