first time at the track with the GN
longbedGTs
high on gas fumes
Sep 21, 2003
270
45
28
Texas
I'm heading out to test and tune in a little bit. This will be the first time at the track with the GN. Not sure what to expect but am thinking it should atleast throw down a mid 12.
Mods:
-Te-44 with hard MAF pipe and cone filter
-25psi with alky
-3" RJC downpipe/test pipe/2.5"Hooker super comp mufflers and tail pipes
-Powerlogger with TT 5.7 WB chip and 60# injectors
-Husek built 2004R with 2800 LU
-Nitto 555R DRs 245/50/16
I'll update this thread later with the results. Haven't been to the strip in 5 years. Should be fun!
longbedGTs
high on gas fumes
Sep 21, 2003
270
45
28
Texas
The GN ran like a champ! Drove there and back...not a single problem. I aired the Nittos down to 24psi(maybe I should have went lower) and it hooked well, but the 2nd gear shift would break them loose for a second. A longer burnout seemed to cure that.
I made 6 passes...all with 2.0+ 60foot times. I just can't hold more than a few psi without breaking the DRs loose. No matter what I tried, the 60ft times were horrible.
Results(best of the 6):
60ft.....1/8(mph).....1/4(mph)
2.0...8.1(88.0)...12.6(108.2)
2.2...8.4(88.0)...12.9(108.5)
2.1...8.2(89.0)...12.7(109.5)
Despite the horrible 60ft times, I can't be more impressed with this car. I don't even mind that it 60fts like crap. It's just a fun cruiser anyway...and now I know it's a mid 12 second car. I'm ok with that(until the bug bites me even worse).
buddy
804
130
43
New Jersey
Very cool. I have Siamese setup besides I have factory trans and factory downpipe. I just ran 12.9 @107 with 2.3 60 ft time. Seems similar times to yours. I'm hoping to get back there this week and shave some of that 60 ft off. I launchrd at 0 boost FYI.
Mr.Spool
4,334
571
113
Air the dr down they won't hook at 24psi start at 18psi and leave with boost use the brake to hold the car.should be 60 ft in the 1.6 range. These cars can 60ft great and It drops a ton off the et the fun factor of a good hook will make that grin even bigger:D
Pronto
Chaos is a ladder.
Dec 9, 2002
12,017
1,186
113
Nashua, NH
Air down, good 5 second burnout and try more boost at launch to hit the tires. A 1.7 60 will feel good, a 1.5 is a grin.
  • Like
Reactions: Mr.Spool
longbedGTs
high on gas fumes
Sep 21, 2003
270
45
28
Texas
What kind of 60ft would it take to get in the 11s? I didn't even think to air the tires down more...the powerlogger wasn't saving files for some reason and I was too focused on that. I didn't get a single log saved. Maybe I'll have to hit the track again and try 18psi in the tires. Also had some time adjusting to wearing a helmet. I couldn't hear a thing that the motor was doing and one run I broke the tires loose at the line while trying to build boost. I still had a blast either way. This is the fastest car I've ever owned(or ridden in), so this is one heck of a learning curve.
Pronto
Chaos is a ladder.
Dec 9, 2002
12,017
1,186
113
Nashua, NH
Time to go again. Take your time to start a routine. Make sure you know how to log and save a run with the Powerlogger.
87GN864
48
8
8
Greenville, SC
I may be wrong but in my opinion it would need at least a 1.7x 60ft to crack the 11s . Congrats on the times. It's definitely fun and the bug will definitely bite you. When I first got my car I just wanted a 7 second 1/8 mile... then it turned into 7.50s...then .30s...then 7.0x... see where this is going? Lol
turbo89
2,414
415
83
Visit site
With cooler weather and a 1.60 60 foot i bet that car runs 11's @ 111-112
Just set a routine and practice a bit.. 11's all day
buddy
804
130
43
New Jersey
What ets are guys running with a 108 trap speed. Just curious I ran high 12's with a launch off idle 2.4 6o ft. time.
longbedGTs
high on gas fumes
Sep 21, 2003
270
45
28
Texas
Might as well bump this thread because I'm going back this Friday for another try. 2 years later but...better late than never. :oops:
Last test & tune of the season and nothings changed on the cars setup...but the two things I'll be doing differently is airing the tires down to the mid teens or so, and writing down the steps to save the datalogs so I don't forget in the heat of the moment like last time.
