john keskes
- Dec 29, 2012
SignUp Now!As I said in my last post,you were lean and it was time to add the regulator.You posted O2 numbers of .695 and .742. Those numbers are very lean and seem to be erratic based on the order they were recorded. You added more boost without raising the fuel pressure and noted a .702 O2 number. This is still very lean. It's extremely lean,if you noted this number as soon as you went WOT. The number you want to see,when you first go full throttle is something over .800. The standard number to shoot for is .780,but that is after a full quarter mile run going through the traps. Turn the boost back down. Check your blm number at idle. If it's high,look for a leak. Then check for a one to one rise in fuel pressure. You have a fuel delivery problem.I am diligently trying to prove a point on max boost with stock chip. All was great up until 5 minutes ago. 39 psi line off stock regulator. 13psi no knock whatsoever. 15psi - 6 plus degrees at 707 o2 (did not stay in it and never hit WOT) Adjustable fuel regulator 43 psi line off. Now she runs with hesitation and stutter no boost and knock under just about any level of boost. Running generally like crap now. Guys have told me they are watching this thread to see progress so I'm being diligent, not to mention I'm curious myself. The vacuum line to the new regulator is a bit of a bend but does not look pinched (the new regulator is a bit taller than stock).
Joel
Incorrect. It doesn't change the duration of on time of the injector,but the extra pressure pushes more fuel through the nozzle while the injector is open. The motor gets more fuel. It will still rise one to one,but you'll start at a higher number and rise one to one up to a higher number.The adjustable would not add anything additional to the stock under boost correct? 1:1.
Joel
It's an "adjustable" pressure regulator and that means you can use it to control the amount of fuel the engine receives.It is a "pressure" regulator and thats that
Lol, ok i left out the "adjustable" part.It's an "adjustable" pressure regulator and that means you can use it to control the amount of fuel the engine receives.
i spent a bit of time on the car tonight
i unplugged the ecm wire for a bit while i looked around the motor for loose hoses and the like. then started her up and drove around the block. still running like crap. i sat and idled and noticed the bl going from 117 to 140 and then back again. did this 4 or 5 times and then settled at 117. i had been 128 before regulator.
we4Mateo - you've only come off one way, that is super helpful.
I would think that for the experienced guys like yourself, watching a newbie like me plod through the steps you've been through a 100 times is a bit amusing and likely frustrating to some. I was just really curious to see how far I could get with a stock tune. Seems like for me it was 13psi.
I am really looking forward to getting her dialed in at 17 or so. I'm close.
Today was the first real setback.
I'm learning a ton and your help is really appreciated.
I hope others will benefit from the posts.
Joel
Stock squirters should be fine for his goal, might need cleaned thoare you on stock injectors?
I dont under stand why the chip has not yet been installed my self. He said he was trying to prove a point, and i told him its been done. Point proven, put that chip in or setting for less with the stock fpr back onThe TT chip and set the fp to 43 with the line off and see how it runs.
He's wanting to see,for himself,if he can run 17 lbs of boost with the stock chip and today's 93 octane. He hasn't done it yet,so the point hasn't been proven. According to we4Mateo and ZNix,this has not been done because it is impossible. We'll see. Joel works 23 hours/day and 364.5 days per year. The rest of his time is open for family and his car. As you can see,it takes him a long time to get any single thing done to his car.I dont under stand why the chip has not yet been installed my self. He said he was trying to prove a point, and i told him its been done. Point proven, put that chip in or setting for less with the stock fpr back on
