First time at track
dragway
First time at track today wasn't very happy with time best et was 13.2 at 102 on street tires . I knew I would run a god et with street tires but thought it would mph better . o2 sensor 750 boost 22-23 with alky
I'm thinking you did fine on your first trip. Time slips? Did you get any?
Post em up, maybe we can make some suggestions on improvement.
Rich
Looks like it is laying down on the top end. Valve springs been replaced?
Fuel pump with hot wire in good condition?
You say 22psi boost, and Alky too. I would want way more mph with that. Like 110 or more.
Plugs new, fuel filter new, plug wires been ohmed out? Fresh gas?
Needs some sorting.
You'll get it there, just takes some work.
Needs some sorting.
^^^^what he said. It should mph a little better. A good thing though is I feel any 60' at 2.0 or quicker is fine on street tires. Good work getting it out at least.
Check numbers on converter with all the other things mentioned.
Your power is way down.
You did well for your first outing especially on street tires. Something is keeping your power down. Maybe your trans is slipping?
