Since I got my '87 it has never wanted to shift from 1-2 on heavy throttle. I have posted here and gotten a couple different ideas, TV cable and the suggestion that it's just not calibrated right, since it's not a BRF. Well, while perusing some of the other messages here I noticed that these trannys tend to starve for fluid under heavy acceleration, and that some folks run them a quart or two high to help prevent that. So, I added a couple quarts (I think it was a little low anyway, but I had just R&Red the driveshaft) and took it for a spin. No more problem...although it doesn't seem to accelerate as fast as I had remembered. It's not exactly neck snapping shifts, but at least it will do it. I have the Poston recalibration kit on order, should be here tomorrow or so. But first, I think I'll replace the filter and RTV the seal, change the fluid, and re-adjust the TV. Maybe I can get this right without a bunch of expensive parts. I may sell the car anyway, so it doesn't hurt to try.
Regardless, for those of you experiencing the lack of 1-2 shifts under heavy throttle, consider checking your fluid and over-filling a little. Alternatively, if you plan to keep your car and put a couple $$$ into it Bruce has a deep pan kit with some kind of filter conversion that (I think) is designed to eliminate this annoying "feature" of our cars.
Later
Jeff
Later
Jeff
