HighDesert-T
- Jun 14, 2002
Took off the carb, fixed the vac line that some genius decided needed to run under the turbo inlet. The idle needed to be adjusted some but not all that much. End note is that is running, not right but, it is running.
What bothers me is the car still will not get into boost. Sometimes it will get into the yellow but not the red. Could the waste gate be stuck open? You can here the turbo spool but there is not a surge of power.
Also, the cable that is under the throttle linkage, what is it for? The end broke and now it will not stay clipped on. The cable runs back behind and under the firewall. Is there any cheap way to fix this other than replacing a cable?
Getting ready to take it in and let the service people handle this.
