Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
The misalignment cant be easily corrected. If you take the precautions you will be good. Weak springs, EOS, and keep the rpm over 2k when breaking in.
Agree.
212/212 Flat tappet, 6K miles, no issues
Just curious, but how can the lifter bore be easily corrected? Also is the idea behind using weak springs to save the cam? Wouldn’t lifter bounce be a concern on a new cam and cause a wiped lobe?
See cam thread in sig
After struggling and thinking about this for a year as well
1. Make sure you assemble correctly. This means getting the cam position right. Belief it or not, you CAN vary the lobe positions by 0.030 if you are not careful.
2. Use the correct assembly lube.
3. Bench bleed the lifters!
4. Make SURE your preload on ALL valves is correct. Verify geometry when you assemble as well and use valve springs with the correct (Low) seat pressure.
5. HAND Prime, prime, prime .......... prime again till you see oil out of ALL pushrods. (Prime till the cows come home :tongue: )
6. Make sure your engine starts right away .... first crank-up. IOW, check, and re-check everything!!
7. (I) Put 1/2 bottle of EOS in the filter before priming, the other halve in the engine with straight 30W oil.
8. Keep RPM at 2000 -2400 - 30 minutes (What I did)
9. Drain the oil, cut the filter, inspect, inspect, inspect.
10. Run EOS with any oil afterwards.
I would never use flat tappet cam over roller , I wiped out two of them killing two motors and they were 206/206 comp cam like yours , properly broken - in I should add , to spend the extra money for roller set up to make more power is not the right reason , flat cams will can make as much power ,BUT for piece of mind , cooler running motor , oil selection without looking for specific additives to stop lobes going south ETC ,ETC ... I would suggest you to go with roller !!!! tha's my 2 cents .
If I had the budget, I would have installed a full roller as well. Hands down, no questions asked!
While there are horrific and expensive nightmares posted about flat tappet cams, I now realize there are just as many (if not more) success stories. Most people who do plan on racing the motor, run flat tappet cams, so it is fair to say that the "majority" of average TR owners run a flat tappet cam.
The decision on a roller for the majority comes down to "Your budget".
JMHO
