Flexplate noise
NorCalTurbos
Slowing down to SPEED UP!!!
Will a bad or loose flywheel make a knocking sound? Today I fired up my car new trans installed about a week ago and it's vibrating and making a knock sound while running once I loosened the tc bolts I noticed the flywheel can be moved left to right a lot of play is this my prob?:banghead:??:banghead:
Yes. Anything that spins and is loose will make noise.
Make sure Flexplate to Crank is 60ft lbs.
Tighten the 3 converter to flexplate bolts. Use loctite on these.
Quite possible its smacking in to starter?
Never mind fellas the flexplat bolts are finger loose I think found my problem.... I'll tighten them and see if the noise stops I'm pretty sure it will
Thanks bro I'm getting after it right now, thanks
Sidebar. I'm in the Bay Area as well and need a built tranny
