SCOOBY DOO
BASED CANADIAN PATRIOT!!
- Feb 18, 2007
If I switched from a stretched SLIC to a FMIC, would it affect throttle response?
SignUp Now!It would not affect throttle responce. It would delay boost buildup. How much, l can't say. Maybe some with experience can chime in.
I noticed no difference in throttle response or lag. What I did notice is increase in power and engine temperature at idle in traffic with the ac on.
Theoretically, as you increase intake plumbing volume, the more you will delay boost buildup. The turbo has more volume that will need to be pressurized. I'm sure this theory is true also. How much of a delay is the big question. My personal guess, because I don't have any first hand experience, is that it would be hard to measure. I'd bet that most people would not be able to tell.Don, I bracket race the car, so spoolup time is at a premium. Maybe sticking with the stretched SLIC might be the better choice.
If you bracket race the car then it shouldn't matter. Just adjust your dial-in.
I can't see it having a negative affect though since you probably will lauch with some boost and the turbo already spooling. I'd imagine that the greatest difference would be while street driving like when you stab the throttle to pass a car.
May I ask what FMIC you purchased?
My car has the V2 front mount and that thing spools insanely fast. It has to work with your total combination. My turbo is a hybrid and considered almost a 70 series, Vigilante 3200 (0-pump), 83# injectors, ME-R MAFless and it rips. I run 21psi on the street and from a dead idle can hit max boost in under a second just mashing it to the floor. WAY better throttle response than any of my hotairs ever had and my old 85 GN was pretty damn fast in the response department.
Don is correct with the theory but some of these cars just don't listen and do it anyway.Like when people used to tell me "you can't run 25psi on a hotair, you'll blow it up". I would tell them to go tell the car then since it had been running that way for years.
Grumpy run's 9s with a stock location intercooler, why do you want to add more weight to the car????????
