What I mean by "semi-budget" is that I willing to buy a high mile junk yard 5.3 liter aluminum block LSx like a L33 but instead of just plopping it into my car with just a change of ARP head bolts and valvesprings. I want to give it a good rebuilding with a machined crank, upgrade to good stock Gen IV rods like out of a LS3/L92, fresh bearings and rings, fully balanced rotating assembly and ARP fasteners everywhere.
My power goal is 600 to 700 RWHP in a daily driven 1995 Chevy Caprice 9C1.
There are two schools of thought regarding making big power on turbo setups especially on budget builds. They are the "the foundation of ANY big power setup is set of good flowing heads" and other is "don't bother porting the heads just let the boost do the work".
Bottomline: Are ported stock 799/243 heads or even aftermarket TFS's or AFR's worth the expense on such a build or shall just forget about it apply the money elsewhere and turn up the boost an extra 1 or 2 psi??? Or can you guys here provide me a middle ground solution between those two schools of thought??????
