Hey Bruce, you mentioned on this old post to not mess with the ML Pressure setting in the PCM.
http://www.turbobuick.com/forums/showthread.php?s=&threadid=51516
Why is this?
Reason for bringing it up again, is I've put in a new motor since then, an LT4, which produces alot more hp at lower rpms than the old motor, with the old original truck settings it would wind up to 6-7k rpms easy before shifting. The MLP setting where raised in the PCM to be more like they are on a f-body (much lighter car than my truck) and the shift points adjusted, now it shifts perfect, but winds up a little in the 3500-5k rpm range, it could be firmer in that range.
Anyway, I want to understand why this may not be a good solution to the loose feeling tranny with the higher hp motor before it burns up if I can prevent it.
Why is this?
