One thing I have noticed with my PT91.5, is that if the converter is to tight, the power just hits the tires to fast and to hard. Dusty losen'd the converter and that fixed the initial hit. The Drag Radials im running now, along with the converter fix, has gotten me some very nice 1.27-1.35 60fts, with out the aid of Coil overs, adjustable shocks. If course we have the nitrous only on spool up, once i let go of the transbreak, it shuts off. Yes, to big of burnouts, can kill your traction with this power level. The boost controller is a life saver, but make sure its not set with to much lag time between the launch stage and the 2-3 stages. Im telling you, if the converter is perfect, then the power will take care of the rest of the run. You will launch, but nothing to crazy on the tires, you grab 2nd and just hang on. 8.50's isnt hard, if the convrter is right and the shifts are on time with a decent 1.39 and under 60ft, carrying 160+
out the back door
