ford 90mm TB throttle cable bracket????
norbs
Classic fast, XFI, SPortsman & MS3 programming
Hi I am in need of some kind of bracket to hold the throttle cable, does any one have some pics?
Norb
Norb
Lokar cable I think.
Very nice, but Looking for an intake with an elbow and stock type throttle cable
Here you go.
Thanks it helps me on the arms part, is that a kinlser 5946 throttle stop 5/16 or 3/8" shaft? are you using the stock spring or kinsler spring? What length is the arm?
Norb,
Kinsler spring.......It is also a custom shaft in an accufab TB. You can use the stock arm with an adapter bolted to it. I made one of these first and later had Kinsler rework the TB with the hardware you see in the picture. This picture is before the Wiggins clamp and the new TB shaft/hardware. I had many problems with the hose coupling blowing off. I finally got sick of the problems and reworked the entire unit. I have no love for Accufab!!
Didn't Champion make one for Don Cruz? I saw pictures somewhere I thought.
