Vibration.
Anytime you swap out a piston set you should rebalance it. If you remove and clean a stock piston/pin and weight it, and if it is with-in a few grams of the TRW ones, then you will be OK. The TRW pistons are pretty light, but they add a HUGE wrist pin to add weight to match the stock pistons. NHRA says that they are legal to use because they weigh similar to the stock piston. (NHRA Stock Eliminator) What most guys do is replace the heavy pin with a good light weight pin to reduce reciprocating mass. It's easier on the rods/bearings.
