SignUp Now!Who make that brace ??
www.gnsperformance.com
ohh,,secrets,,i like it,,, on a unprepped street,,on the R radial ,,,do you prefer squat,,or separation?The ss tire sidewall sucks on the street in a high torque situation with 0 prep to the road.
The 2 tires are incomparable.
The r is the tire to run if you have to run a radial on a unpreped road
What most guys dont understand is that radials really need to be on a radial prepped track to work and grab their advantage over other tires.
You would have to oversize greatly on a radial to get it to work along with an ace driver and proper boost control
Girls squat, racecars don't.do you prefer squat,,or separation?
maximum separation that is controlledohh,,secrets,,i like it,,, on a unprepped street,,on the R radial ,,,do you prefer squat,,or separation?
The rear rails are just "swinging in the breeze" once they are past the rear spring pockets.Chuck, you think that rear frame mounting bar that runs across L to R like the bumper is a good solution to frame twist?
