parts are free, you pay shipping. paypal/check/money orders are fine
all parts are stock parts.
pass side header
driver side header
up-pipe (original insulation in nice shape)
downpipe (the cat flange has been cut off and slip-fit pipe had been welded on)(original insulation in nice shape)
throttle body heater lines
vac hard line cluster that goes from front of intake to rear
steel plate that sits on driver side valve cover that holds the solenoids/switches
front timing cover with oil pump. (very nice shape with minimal cam button wear, cam button appears have little wear and is included)(this is for a 20 bolt oil pan)
throttle cable bracket
egr plenum
starter heat shield
plastic air intake elbow that mounts to tb. has a couple cracks in the acordian part but is a easy fix
will have some more free stuff to add in a couple days.
also have a couple things i'd like to sell since they probably have some value.
2 stock ecms with stock chip and eprom included. (no isssues) $50 each
2 known working stock maf sensors. $25 each
pass side header
driver side header
egr plenum
starter heat shield
