Matthew Jones
- Apr 24, 2013
Ok guys, I need help! I'm at my last rope with this trans.
It's a fresh 200-4R with a bunch of CK Performance parts (Billet forward drum, master rebuild kit, shift recal kit, big servo. I used his manual as well. The trans is an AA code. Converter is a Hughes 2500 lockup. I followed CK's manual to every last word and the process went smoothly. The 1-2 accumulator is plugged.
Problem:
1500RPM (TV in/TV Out)
P: 50/190
R: 100/150
N: 50/190
OD: 50/160
D: 50/160
2/1: 180/180
To me, the pressure is way low for a .555 boost valve. Something is wrong and I can't figure it out. I'm in touch with Chris, but understandably he is a busy guy. So here's what I've tried to fix it:
1. Replace filter
2. Replace VB/case gaskets
3. Double, triple, quadruple check TV cable adjustment
4. Rebuild valve body, triple check the TV valve is not sticking.
5. Replace pump with new unit from CK
6. Replace valve body with known good core (KC3?) from CK (I put in the shift kit from the old VB)
7. Cleaned spacer plate and removed scale from cut surfaces from laser cutting process
8. Opened TV feed orifice in spacer plate to .063"
9. Verify gauge is working properly
10. Verify hose connected to gauge is not plugged
That's it. I don't know what else to do. If or when I find out the problem, I promise to post the culprit! Please help!
Problem:
P: 50/190
R: 100/150
N: 50/190
OD: 50/160
D: 50/160
2/1: 180/180
1. Replace filter
