Fresh trans, 2 converters, Accufab, Champion, HRparts, ARP, Comp Cams, OEM, etc!
TTT, lots more left! Here is what has sold:
Stock 200-4r
PST bushings
HR mounts
70mm parts
Champion alt bracket
Everything else is still available!
i will take the wiper motor if you got the bolts for it
3 bolts that hold it to the car. I think I have them but would like to get a set just in case since they are not comon since they go into the bushing area
Boost231 - I pm'd you back. Im pretty sure I have the screws, will check tomorrow before I box it up for you.
Wiper motor sold
UCC 10" torque converter sold
Here is an updated list of what is still available as of today:
- ARP rod bolts for stock rods $45
http://home.comcast.net/~gnat86/parts/arp1.jpg
- 12" l/u 3000 stall converter but not sure who makes it. Nothing wrong with it, just switched to a non-lockup unit since the combo changed. Here are the numbers stamped on it:
4
2C523K1
3
K3 2R 065
C24HD
$200
http://home.comcast.net/~gnat86/12lu_600.jpg
http://home.comcast.net/~gnat86/12lu2_600.jpg
- Stock balancer with pulley and bolts $95
http://home.comcast.net/~gnat86/parts/bal1.jpg
http://home.comcast.net/~gnat86/parts/bal2.jpg
- One ProGram billet center main cap. Machined only ONCE $50
http://home.comcast.net/~gnat86/parts/cap1.jpg
http://home.comcast.net/~gnat86/parts/cap2.jpg
- Intake heater lines with valve (very nice shape) $95
http://home.comcast.net/~gnat86/parts/heat1.jpg
http://home.comcast.net/~gnat86/parts/heat2.jpg
- Comp 885 "R" series lifters. Very little use (15 passes). $325
http://home.comcast.net/~gnat86/parts/lifters3.jpg
- Manley 5/16" 8.500 pushrod set $60
http://home.comcast.net/~gnat86/parts/pr1.jpg
pm sent on trans.
Sorry, trans is sold (as mentioned above).
- 12" l/u 3000 stall converter. Not sure what brand it is. Nothing wrong with it, just switched to a non-lockup unit since the combo changed. Here are the numbers stamped on it:
4
2C523K1
3
K3 2R 065
C24HD
$200
