turbobrain87
TR's attack!
- May 15, 2004
I need some ideas on how to get this little booger off. Tried it with the turbine wheel "nut" secured in a vice and then a ratchet on the comp nut. No deal. The comp wheel was twisting but the turbine wheel was not!
So I tried to heat it up with a butane torch but no luck there either. I guess a real torch is needed? Can you use an impact on it?
Thanks for any help!!
