sorry for so many questions guys.
OK so Im finally checking the front endplay clearance.
When I pull up all the way on the input shaft it moves up about .015" with a number 3 washer
Then the book says to subtract the snap ring clearance of the shaft and OD carrier, however I have the billet carrier and billet input shaft, which were a pressed fit, although there is clearance (.009") it does not move (very tight)
none the less, am I good?
