83hurstguy
- Sep 18, 2005
17-4 PH isn't cheap... not saying it's $48 worth, but it's definitely more than $10, especially with the flange head shown. If you want carbon steel, yeah you can do it for $10.
I drilled mine to 1/2" and used standard Grade 8 bolts and nylocks, but I have the SPC adjustable uppers so it's easy to access both sides of the bolt/nut.
If you want something that's removable but easily loosened and tightened without having to put a socket or wrench under the control arm, the other option is to grind a flat on a bolt head side, weld a block to the frame next to the bolt head... this way, the bolt can't spin when it's seated, but once the nut is loose you can slip the bolt back for downpipe clearance. Stude engines use that principle on their rear crank to flywheel bolts.
