frank_ster
- Feb 16, 2013
so the head gaskets are on the way.
timming map ? anyone ? please !
other issue i have is me idle , and its something i'm hopping raising the compression, tighter quench and degree-ing the cam will help,
my idle i have to run around 13.7 afr at idle otherwise it will start surging then stall. i wouldn't think this is typical of the buick v6.
another thing is i have seen a photo of a turbo trans am engine and it has the same valve covers as mine ( with the 3 acorn nuts on top )
is there a easy way to install roller rockers on those ? since the only problem is the cover is held on by the rocker studs. just thinking of a way of making this work. i think a typical rocker would work with a long set screw as the locking screw and then the nut will hold on it.
