gunslinger
- Nov 21, 2005
You've either got the wrong rotors or the wrong brackets. With everything bolted down, the rotors should be centered in the brackets. I seem to remember my caliper brackets being wrong when I did my swap. I think I had to use the brackets that came with the S-10 donor stuff, and I used just the new calipers.
Check to see if the other side is centered. Then you'll know that you've got one incorrect bracket, or two incorrect rotors.
Remove the washers...it's going to make your binding issues worse, but they shouldn't be in there.
