Hi All,
I'm just about at the end of my patience! I've had this thing running since last July, but have had it apart several times since - once for head gaskets (crappy machine work) and 3 front cover jobs for oil leaks (something wrong with the front face on my block). My new GM front cover is now cracked in the same place the 2 previous HV front covers cracked - the second from bottom, DR side bolt hole (top mount for crank sensor bracket). It seems as if there is a "depression" in the block face that the cover is trying to conform to when tightened.
But anyhow, I can (and will) live with the leaks IF ONLY THIS THING WOULD START! The last time I removed the front cover, this is what was done:
Could my plugs be gapped too much?
Will it start with a bad or no MAF?
It spins over normal for 3 -4 spins, then cranks like it has 15:1 compression! If I disconnect the crank sensor, it continues to spin over normally.
After the 4th spin or so (whenever cranking slows and becomes erratic), the gauges all go nuts.
T-Link shows VERY low voltage on it's "battery" gauge when this happens (even though no wiring changes have been made).
<edit> forgot to add:
Last time this thing actually ran, there was some muted "popping" noises from the exhaust with engine speed changes (kinda like small back-firing?)
The motor has always needed 6-8 spins to start - it would never fire on the 2nd revolution like it should...
<edit>
I plan to remove the injectors and check each of them individually, regap the plugs @ 0.030", recheck all power and ground connections, run the C3I diagnostic procedure...
Am I overlooking something simple???? I've made fairly standard changes, nothing at all to the wiring, but it refuses to start!
HELP!
- Jason's powerplate
- ATR PCV check valve
- new Delco O2 sensor
- MSD 50#er's and PTE chip
- new IAC motor
- new Autolite #24's (@0.035")
- checked for timing gear alignment, OK)
- new GM front cover (self-machined for Weber roller cam thrust setup - set @ 0.015")
- pulled thrust nose, cam sensor gear, "eccentric spacer", timing gear, & thrust spacer - did Weber's "oiling mods" and re-installled
- checked timing gear alignment (again - OK)
- new Optima red top battery
<edit>
HELP!
