FS:Aeromotive Pro Pump
fallguy
For racers running high horsepower EFI engines up to 2000 HP naturally aspirated, and forced induction EFI engines up to 1450 HP, this is the pump for you! A state-of-the-art, patent-pending, ''dual chamber'' pump design, coupled with Aeromotive's famous proprietary aerospace composite technology, provides you with performance unsurpassed by our competition. This performance pump simply doesn't wear out. Flows more than 1000 lbs. per hours @ 13.5 Volts and 45 PSI. This pump features -12AN ports. The pump body is beautifully plated with an indestructible electroless nickel process.
I ran this last year. Perfect condition.
$550
email fallguy@hotmail.com
Since I can't figure out where the edit tab is I'll just post and add new pics of actual pump.
I just used it for drag racing, so I used it without. I had around 50 passes last year with car with that pump.
