Weldon 2035A pump NEW
TYRFRYR
Weldon 2035A pump NEW, never used or mounted.
$780 plus shipping (and paypal).
http://www.weldonracing.com/product/1-6/D2035-A_(-12_inlet_and_-10_outlet).html
Maximum Horsepower
1800 hp @ 14 V, EFI and Carb engines (900 hp on Methanol)
GPH/PSI Range: 180-210 GPH/0-80 PSI
Considerations: If your actual horsepower is close to the Max HP limit and/or you are considering a larger power adder, see Part # 2345-A
Features
  • All billet body pumps are 100% serviceable/repairable
  • Self Priming
    Pump may be mounted above fuel cell
    Vertical or horizontal mount
  • Breakaway coupling prevents pump/motor damage in the event of fuel contamination
  • All internal components are 100% metallic
    No plastics or composite materials. Our internal pumping
    elements are made of high speed tool steel and bronze.
    This results in the longest lasting, highest quality, most durable
    pumps available.
  • Body machined from billet aluminum
  • For carbureted and injected engines
  • Provides Consistent Performance with no fall-off in flow
  • Precise fuel delivery
  • Blades self-compensating for wear
  • 5.5 lbs
    Current Fluids
    Weldon Pumps offer the widest range of fuel compatibility.
    Gasoline - Methanol - Nitro methane - Diesel - Ethanol - All racing fuels
    Comments
    Requires appropriate bypass regulator, a -8 return line is recommended.
Tyson
831-252-2106
Bump.
Low price...$725 shipped. If interested please text the number below.
Tyson
831-252-2106
Bump.
Lower price...$725 shipped. If interested please text the number below.
Tyson
831-252-2106
