ttypewhite
- Oct 1, 2001
Selling my used Weldon pump for $550. Its in perfect working order, zero issues. Comes with fittings. Below are the specs off Weldons website:
Performance Chart, GPH, PSI, Amps
Dimensional Drawing
Fitting, -10ANM to -12 STM
AN Port Adapters
EFI and Carbureted Filter Assembly
10 Micron Cellulose Filter Assembly
2046 Series, Blocking Regulator
A2040 Series, Bypass Regulator
A2047 Series, High Flow Bypass Regulator
14000 Fuel Pump Controller
40 Micron Cellulous Filter Assembly
2345-A (-12 inlet and -10 outlet)
8850-10E / 12V Replacement Motor
Maximum Horsepower
1800 hp @ 14 V, EFI and Carb engines (900 hp on Methanol)
GPH/PSI Range: 180-210 GPH/0-80 PSI
Considerations: If your actual horsepower is close to the Max HP limit and/or you are considering a larger power adder, see Part # 2345-A
Features
All billet body pumps are 100% serviceable/repairable
Self Priming
Pump may be mounted above fuel cell
Vertical or horizontal mount
Breakaway coupling prevents pump/motor damage in the event of fuel contamination
All internal components are 100% metallic
No plastics or composite materials. Our internal pumping
elements are made of high speed tool steel and bronze.
This results in the longest lasting, highest quality, most durable
pumps available.
Body machined from billet aluminum
For carbureted and injected engines
Provides Consistent Performance with no fall-off in flow
Precise fuel delivery
Blades self-compensating for wear
5.5 lbs
Current Fluids
Weldon Pumps offer the widest range of fuel compatibility.
Gasoline - Methanol - Nitro methane - Diesel - Ethanol - All racing fuels
Comments
Requires appropriate bypass regulator, a -8 return line is recommended.
Dimensional Drawing
AN Port Adapters
Maximum Horsepower
Features
Self Priming
pumps available.
5.5 lbs
Current Fluids
Comments
