Weldon C2015 Fuel Pump
J-B Racing
Forced Induction
This Pump has not many miles on as it was used only for Drag Racing
Maximum HP:
1000 hp @ 14V EFI (500 hp on Methanol)
1050 hp @14V carb (525 hp on Methanol)
GPH/PSI Range: 85-115 GPH/0-160 PSI
Features
All billet body pumps are 100% serviceable/repairable
Self Priming
- Pump may be mounted above fuel cell
vertical or horizontal mount
Breakaway coupling prevents pump/motor damage in the event of contamination
All internal wear components are 100% metallic
No plastics or composite materials. Our internal pumping elements are made of high speed tool steel and bronze. This results in the longest lasting, highest quality most durable pump available.
Body machined from billet aluminum
For carbureted or injected engines
Provides Consistent Performance with no fall-off in flow
Precise fuel delivery
Blades self-compensating for wear
This Pump new goes for $700 US
Asking $350
