Found some copper in my oil filter so it was torn down and will need to be gone thru as it hurt the main bearings. Block is fine as is the cylinder walls. Crank appears to be fine as well but Im unsure to be honest.
The engine had approximately 500 miles on the last rebuild with stock pistons and new GM rings (std). The stock turbo crank was cut .010/.010 with Clevite bearings and resized stock rods with ARP waveloc bolts and held in place with two center billet main caps and ARP main studs. Comp Cams 212/212 flat tappet camshaft and timing set included.
$600 obo plus shipping. Does not include timing cover or oil pan.
Thanks, Bill
Thanks, Bill
