Below is a list of parts for sale along with the link to the photobucket with pictures of everything. Please post or PM me with any questions you may have. I am located in Cedar Park TX just north of Austin. Thanks, Jeff
camaroguy1969/SNJ Parts 081008 - Photobucket - Video and Image Hosting
1. Lincoln Mark 8 Cooling fan. Must use a 30 amp fuse and relay with it. Good condition, ready to use. $100 OBO
2. Moroso Fuel Cooler. Good shape, ready to use with AN fittings. $80 OBO
3. Buick Regal/GN front lighting harness. $80.00 OBO
4. 13” Aftermarket electric cooling fans, in good shape, ready to use. $50 for the pair OBO.
5. Buick Regal/GN AC controls $20.00 OBO
6. Comp Cams 210/205 camshaft for GN V6. $110 OBO
7. 86-87 GN turbo, no play but turbine feels a little tight. $120 OBO
8. 86-87 GN turbo, turbine wheel is ruined, good core for rebuild. $120 OBO
9. 82-85 Hot air turbo, in good shape. $120
10. 2 under hood lights for Regal/MC/Cutlass $15 OBO
11. 1 door striker flex arm for Regal/MC/Cutlass $5 OBO
12. LT1 or LS1 Mass Air Flow Sensor. Untested, looks good, $50 OBO
13. Stock T-56 6-speed shifter, very low miles, in excellent shape. $70 OBO
14. GN fuel rail, injectors, and pressure regulator. Injector size and condition unknown. $80 OBO
15. Black GN rear quarter window trim, in very good shape, all mounting tabs in tact. $20.00 OBO
16. Black GN/Regal parking light surround trim, in excellent shape. $20.00 OBO
17. High Flow aluminum after market turbo inlet wo/air fitting. $20.00 OBO
18. Stock GN turbo inlet $20.00 OBO
19. Rocker arm sets, 3 complete sets, 1 set has one rail that is missing a rocker arm. 45.00 OBO per set
20. GN electric fan with resistor and pigtail. Good condition and ready to use. $50.00 obo
21. GN Powermaster brake master cylinder setup. Appear to be complete, condition unknown. $200.00 OBO
22. GN starter, condition unknown. $50.00 OBO
23. GN electric cooling fan with extra resistor and pigtail. $50.00 OBO
24. GM door locks with 2 keys, black trim, good shape. $25.00 OBO
25. New set of LT1 Z28 valve springs, in the package. $60 OBO
26. Aftermarket transmission cooler, new in box. $30 OBO
27. GN dog house and 2 throttle bodies, incomplete for parts. $100 OBO
28. LT1 or LS1 Mass Air Flow sensor aluminum body only. $15 OBO
29. New GN/MC high beam switch by Borg Warner, new in box. $20 OBO
30. Assortment of turbo vacuum actuators. $100 OBO for All
31. Set of 6 GN Fuel Injectors. Each injector as the number 45541247 molded on them. 75.00 OBO – Believe they are 36lb blue tops
32. Dual Battery Isolator by BMC part number PR-3D. New in box. $40 OBO
33. GN Water Pump and Crank Pulleys, in very good shape. $30 OBO
34. GN 200R-4 Transmission pan in excellent shape. $30 OBO
35. GN Torque Converter Cover in good shape. $10 OBO
36. Regal/GN AC controls in good shape. $10 OBO
37. Power Antenna for GN and MC? $40 OBO
38. GN Driver side under dash trim with heater vent. $10 OBO
39. GN or MC Upper Radiator supports. Both in good shape. $30 OBO
40. 2 GN test pipes with bolt on cut outs. $40 OBO EACH
41. 2 Turbo Intercooled V6 GN downpipes with no cat. $40 OBO EACH
42. 2 Turbo Hot Air V6 GN downpipes with no cat. $40 OBO EACH
43. 3 Turbo Intercooled V6 GN downpipes with gutted cats. $40 OBO EACH
44. GN Front Sway Bar $$??
45. 1 driveshaft unknown $70 OBO
46. 1 GN Transmission Cross-member, in good shape. $50 OBO
47. 2 Passenger side Regal/GN outer fenders. $50 OBO EACH
48. 1 Passenger side Regal/GN inner fender support. $50 OBO
