Fuel adjustment through TT chip ?
ikle
When I pull overall WOT fuel out through the TT chip how much should I pull out at a time to bring WBO2 #'s from 11.20 to 11.40 ? Also when I pull the overall WOT fuel out if I need to add WOT fuel in 1st gear I would add this to the fuel that has been already pulled out.Example: if I remove 1.6% of overall WOT fuel I would have to add 1.6% of fuel to get back to the deffault setting for WOT in 1st gear correct?Thanks,ikle.
To go from 11.20 to 11.40 a/f is about 2%.
WOT fuel affects all gears. If you reduce it 2%, all gears get leaner by 2%. If for some reason, you didn't want 1st gear to get 2% leaner, then you would add 2% back to the WOT 1st gear adjustment.
Eric
