fuel cell 2 340 pumps h&r trans mount & frame, wideband egt
ericttype
  1. aluminum 15 gallon fuel cell with gm sender i installed 2 340 pumps they are wired with 10g and can have 1 pump run and second pump come on under boost, the cell has never had gas in it the pumps have very little run time, i have the mounting straps, i was going to use in my car, the cell is painted black and does have scatches from sitting around not perfect but will work $450
  2. heated 02 sensor plug and play comes with new 02 sensor $65.00
  3. scanmaster shade cover with turbo 6 engraved $22.00
  4. wideband 02 glowshift working order comes with 02 there are some bare wire where i tapped into for power logger but works cheap $70.00
  5. H&R trans mount & crossmember to frame mounts it is missing 1 bolt $120. cost me over $160+
  6. single probe egt come with probe digital read out it is auber adjustable can put a audible alarm warning $50
  7. valve cover spacers so you can run stock valve covers with roller rockers have 7 bolts missing 1 bolt $60.00
  8. front mount intercooler 3" comes with aluminum pipes intercooler measures 29L x 10" wide x 5" thick, the pipes have scatches and the one going to turbo i had to trim but it works great i have clamps and hosed for 3" & some smaller, the up pipe is set up for dual alky and has a 1/8 pipe threads can block off or measure boost pressure, $450
  9. ls style started 1 year old works great $60.00 cranks faster and weighs less
  10. rear battery mount new cables ends mounting hardware the box is used $75.00
