NachoBlanco
- Feb 7, 2005
Which way does the fuel flow through a stock 85/85 fuel rail? Also, I need to adapt -6 an fittings to the rail and regulator. I believe the fuel rail is 16mm X1.50 and that the regulator is 14mm X 1.50, but is it a o-ring or non-o-ring seal? Anyone have a picture of the stock feed line end and stock return line end?
