SignUp Now!nuttin im still running my old 4.1 4 barrel motor but my transmission is slippin so i decided i was gonna swap the whole motor to a v8 but one of my friends was sellin the full swap for 1500 and it was a deal i couldnt pass up so i bought it. when i finish the swap ima post the 4.1 up here to sell it its in perfect condition jus the transmission is bad Beacuse of burning out with 22s
Well if you put the SFI intercooled engine in it with out changing the rear gears on 22's you'll just burn the tranny out again. First things first. If you just want the car to move down the road you should just be able to swap the trannys and drive it until it burns out again.
What does it matter if he has 22's? I dont see how this will hurt the trans.
If you change the tires to such a tall size it will load the tranny more.
