Alright, Ive got some more questions, will the 36lb injectors only run with a chip? Or is the chip just designed to get the most out of them? Is it impossible to run the 36lbs on a stock or kenne bell chip? I have to be able to use a stock chip to pass smog......Also, what is the largest fuel injector size that does not require a chip?
