fuel lines
no-nos
Junior Member
hay guys, the fuel lines that run along the under-carrige of my gn are leaking gas. Does anyone know where we can buy a new set of these,:confused: i would try to save the rails but it's got too much rust on them
Thanks in advance
Carlos
I am stuck in the same situation. I have heard though, that you have to take the body off the frame to replace the rails. Is this true? If so, I think I will end up biting the bullet and running SS braided lines instead. My car has been stuck in hibernation for the past few years with this problem. I dont have the means to pull the body off the frame, so Im still hunting for other means. I sent an email to them, and here is what I heard back:
Jason,
Thanks for your inquiry. here are the part numbers you need.
BUF1013 Tank to pump line $99.00 in OE $119.00 in SS
BUR1005 Return line $79.00 in OE $99.00 in SS
BUV1003 Vapor Line $79.00 in OE $99.00 in SS
BUF1024 Fuel rail feed line $79.00 in OE $89.00 in SS
BUR1012 Fuel rail Return line $79.00 in OE $99.00 in SS
man i hope we don't have to take the body off :eek: , i ordere the parts already, i asked my mecanic info on this but no answer yet:confused:
i'll let you know what he says. if it helps
Run hard line(atleast from the tank into engine bay) its cheaper and stronger than braided flex line. 304 ss wil cost you about 100 bucks, alum 30-50.
The body might only need to come up a couple of inches. Maybe there is a way just take out the body mount bolts in the back and jack up the body with a floor jack?
They'll go in without jacking the body, just persevere! I didn't do this (and wasted several hours), but try an electrical "fishtape" to get the lines past the front suspension area. BTW, the Classic lines come folded in half, so don't freak when you open the package!
thanks for the heads up guys, i know i would have freaked-out had if i were to open the box and see the fuel lines bent in half:D , i will try the fish tape
seems like a good idea :smile:
thanks again
