Guess i am looking at the wrong thing.Not needed. This isn't your issue
SignUp Now!Guess i am looking at the wrong thing.Not needed. This isn't your issue
Turbo Tweak chip,Deka 60# injectorsWhat chip and injectors
I was thinking it should drop more than just one psi.Since your idle vacuum is 16", the pressure should be dropping to about 35psi with vacuum line on (or close to that), if you have the line off pressure set to 43.
Not checked it at the line . just what the boost gauge was showing inside the car,Vac line to regulator actually have 16" on it? Or, is there a misplaced check valve in there, someplace?
The vacuum gauge is at -16 at idle.
I will have to check. To cold tonight to check it.ThanksDoes it read 16"hg at the fuel regulator line?
More than once has an internal rust flake started acting as a check valve and ran people ragged.
Set your fuel pressure to 50 psi line off. Reconnect the line and observe the pressure drop. If it still drops 1 psi,you have a restriction in the vacuum line or a bad regulator. If the pressure drops 5-7 psi,you have a restriction in the return line.I will have to check. To cold tonight to check it.Thanks
I will check there first..ThanksLook at the return line down by the crossmember. There's a bend that likes to kink right at the couplers. If that line get's pinched it can cause high readings.
Don't be concerned about what the pressure does when you turn the ignition switch to the off position. Disconnect the front flexible return line where it connects to the hard return line at the drivers side of the front of the engine cross member. Place the open end of the flexible line in a bucket and start the engine and see how low you can get the pressure down to.Pulled the line apart in front of tank . Put air to it blowing bubbles in the tank took off regulator and blew air threw it back to tank everything is clear. put it back together. Set pressure at 43 line off line back on dropped one psi. so i gave the regulator about 2-3 more turns out nothing changed. shut the car off the gauge dropped to 20 psi instance. start it back up stays at 42 turn regulator back in 2-3 turns then shut car off it stays at 40 looks like the fuel pump is putting out more than return line can handle??
I have to agree with this.Not needed. This isn't your issue
