Only the ability to build high pressure at low volume. It doesnt rule out the pump until it flows volume and pressure.[/QUOTE
Ok what I did again, was pinched the return line with some channel locks and kept it pinched pretty much all the way while the car was idling. I then went to look up real quick at the fuel pressure gauge and I seen the gauge go all the way up to 80# or so. The funny thing was, or not soo funny...hehe, was Istood there and watched the gauge go all the way down from 80# to under 20# and it kept dropping. I then want and released the channel locks from the return line under the car, and went back up to the look at the gauge again, and it went back to around 39# or so with the line on, where I originally had it. So Im assuming I have a fuel pump problem after all right?..Also I did the mighty vac test with the car at idle, and pumped pressure into the regulator once again...around 15 pounds or so, and I watched it drop slowly again from 15# down to under 5#.
Is it safe to assume Im having a fuel pump issue???? I dont know of anyone that has a good one for me to test, so I will have to buy another...Is there anything else I should check once I install the new pump and have the tank dropped again??? I want to get this thing fixed and over with, I have been having this on going problem with my fuel pressure not rising for a couple of years or so. I have more or less been just dealing with it. I dont want to do this anymore, I want to fix this once and for all and get this thing to flow the fuel its supposed to...Im sure you guys understand. The funny thing is, Ive replaced the fuel pump twice now and the regulator twice, only to have the same problem for two years..I mean what are the odds of the fuel pump twice and two regulators?? and still trying to locate the problem...Lemme know your thoughts on this plz, because I will figure it out, I can guarantee that..I bet its something soo simple that im not looking for or overlooking. While I was under the car doing the pinch test..lol I was looking at the return line connections, and the other fuel line..feed line I guess it is, and spraying some soapy water all around there to see if I could see any bubbling or any other signs of abnormalty while the car was idling, but couldnt see anything out of the ordinary..Dunno lemme know your thoughts and thx again....
jojo
