Guys?? Ive done everything to try and find the cause of this. Fuel pressure regulator is brand new!! 60# inj are fairly new!! Fuel Pump is new!! and tested. Dropped the tank and check this, aslo blew high pressure air thru the line from the back of the disconnected fuel line all the way thru the line that runs on the passenger side of the motor. Blew air until it blasted out whatever fuel was left in there along with the pressure of the air after the fact..Ive hooked up a fuel pressure gauge twice dammit!! while driving with someone in the car monitoring the gauge under boost both times. Fuel pressure is set at 45-46 pounds line off. under 25# of boost the gauge did not go up above 45-47# or so...WTF?? The only thing I havent done yet is replace the original factory fuel lines. Oh and yes the fuel filter is pretty new also. I dont know what im missing here, I thought ive tried it all, but please let me know the guys that have had this same problem, and what you did to fix it. I know the fuel pressure should be rising for each # of boost ran. That gauge should have read 70# of freakin pressure under 25# of boost!!. And yes the fuel pump is a Walboro 340, hotwired and about a year old if that..
I dont want to post another thread, as ive read a lot on the BLM thing, but for what its worth, I cannot get mine down under 160. Ive checked vaccum lines ect... the basics, egr, new delco pcv, sprayed the **** out of the lines for leaks ect..The only thing different I did, was had an original Extender chip w/21/19 of timing, then I added the Julio Alky kit, and coincidentally my BL went from 134 or so at idle in closed loop with engine hot after taking it for a run, then let it sit and idle. The BL on the scanmaster would not drop under 160. At cruise they usally maintain about 138 or so.
Comments, Expert advice, Trial and Error fixes, from all the guys that have been able to fix these same problems, please throw your advise and fixes here.
Thx
Jojo
Thx
Jojo
