turbobose13
- Nov 18, 2004
Can some one help me out with my fuel problem, thank you
SignUp Now!We'll need just a little more detail in order to help you.
What sort of problem are you having?
Jim
You should get an additional 1 PSI of fuel pressure per 1 PSI of boost. So if you're running 15 PSI and you're at 38-39 PSI then you should have 53-54 PSI of fuel pressure. If it drops while you are still on the throttle - and boost is constant - then you have some sort of delivery problem. It could be the regulator (not likely) or the fuel pump itself (more likely).
I assume you have an aftermarket pump and that it's hotwired?
Jim
I used to see 60psi and like i said, after i ghanged the pump it worked good for awhile and then every thang went south. what do you guy's think of the Holly forced induction 255 LPH pump, because i got the 100.00 Dollar walbro pump now. thank's guy's.
1.Depending on how the pump was done, it could be that the connector hose from pump to line, has split, a clamp come loose.
2. If the $100 Walbro is one of the Chinese knockoffs, it may well be on it's way out.
3. The Holley pump is actually made by Walbro, and will work ok.
