T talstar New Member Joined Jun 13, 2001 May 25, 2002 #1 What fuel pressure should I have at idle with 42lb injectors?
G Geoff87 Administrator Staff member Joined May 24, 2001 May 25, 2002 #2 Ask the chip maker. Or refer to your scantool.
D Dean Guest May 25, 2002 #3 Start @ 44 base and then, as Geoff87 noted, refer to your scan tool readings to decide which direction you need to go.
