I'm not a big fan of Aeromotive pumps on boosted applications. The flow chart I saw showed 600#@70psi which would work out to just over 800 FLYWHEEL hp on E85. Not enough for 800 rwhp. If you need to run 30 psi of boost or 80 psi of fuel pressure, you're under 700 rwhp.
Which Aeromotive? I'm running a Pro-Series with 39psi base pressure. With 24lbs of boost it made 800rwhp w/ 160lb injectors. And there is still quite a bit of I.D. on the table. I've run this Pro-Series now for two years on the street with no voltage controller, either. Granted, the car is just a weekend toy and I wouldn't want to drive it across the country like this, but for a 30-40 mile drive it has proven reliable thus far.
